Gain....And i even used the SEARCH button
^ what he said...just in case....
P = Power in Watts
I = Current in Amps
V = EMF in Volts
R = Resistance (or Nominal Impedance) in Ohms
Power: P = I x V
Current: I = V / R
Power in terms of Voltage & Resistance:
P = V/R x V
P = (V^2)/R
ok my question is, is the voltage equal to the impedance of the subs or the final impedance? b/c i'm running a kicker kx1200.1@1ohm w/ 2 dual 4ohm subs and i'm supposedly sposed to set it to like 32volts? if it's the impedence of the subs itself then i'd set it to like 70..someone clarify for me?
To get pink noise to use:http://www.moshier.net/pink.html
My theory is this would be an easier way to determine the voltage, since with normal music voltage can change very drastically very quickly.
Pink noise is used for checking frequency response or power bandwidth with a spectrum analyzer, but it's a lousy choice for power or gain checking with a DMM. Use a fixed frequency sine wave on a CD, 50 Hz for sub amps or 400 Hz for speaker amps.
PartyInThRanger
Ambulance with Bass
PartyInThRanger
Middletown, NY
dan7532
