fusing dual power wire???
I could be way off here, but I think that the two imputs on the amp are internally connected to the same power supply. You can test this by running a continuity check on the two imputs with a DMM. Therefor your current would be added together at the node, so assuming both conductors carry equal current that is the proper way of doing it. Someone correct me if I am wrong
The amps are not fused themselves. I am considering using smaller gauge wire for the 200 and 300 watt amps (I believe they only recommend 12 awg...
152
463
946
RangerDangerV2
RangerDangerV2
st cloud MN
All_Logix
    Jun 1, 2024
    May 31, 2024
