fuses
  • 4
Matador
-= StillBumping =-
2,050
Ca
is there much difference between ANL fuses and AGU inline fuses, besides ANL supporting higher current fuses.
it's going to be for the amp power wire (4gauge), amp being around 800-1200watts rms. most likely bet 1000-1200watts rms.
also, the remote wire of the amp, is it just one size? or it also depends on the power wire?
coo. hmm, 2 gauge? 4 gauge should be fine tho right:D 2 gauge is more $$$ n kinda harder to find i think, at least from wat i ve seen. thanks tho, hmm... 120amps should be ifne? the higher the current support means?
thanks
4AWG should support up to about 2000W without overheating, but using 2AWG won't hurt anything at all. If you plan to run hard loads for a long time (ie. bass tracks), it would be better to just make the jump to 2AWG. And don't worry about 0/1AWG, because that's for 10KW+ applications.
As for what amperage fuse you need, that depends on the amplifier. It is best to use whatever the amp uses. For example, if there is a single 25A fuse on the amp, use a 25A fuse on the power wire. If it has two 30A fuses, use a 60A on the power wire, so on and so forth.
Originally posted by Matador how does the fuse breaker work? how would u implement it?
A breaker would do the same thing as it would in your house. If it pops you just reset it. You don't have to buy more fuses. They install inline like a fuse would.
Matador
-= StillBumping =-
Matador
Ca
MikeofTulsa
    May 16, 2024
    May 16, 2024
