Fuse question
  • 5
150A. Fuse for the max rating of the wire, which for 4g OFC is usually 150A. If you start popping fuses, swap out the 4g for some 1/0 and fuse for 250-300A, depending if you buy CCA or OFC
what wire do you have, 4 gauge in car audio is too broad of a sweep because of the variations of wire. generic no name usually are fused @ 60a, good stuff like Kicker Hyperflex gets fused @ 100a.
I just took a look at the terminals, I REALLY think you could squeeze 1/0 in there. Make an excellent ground for it, and fuse for (2000watts/13volts)=~150amps.
I made a lot of money repairing fuse boxes that were destroyed from people taping into them. Pay once by doing it right. Do it wrong, the second...
14
479
It would be cheaper, it might be easier to find a place to mount it, and you would have a ton of options if you just do two, 3 slot fuse holders...
639
My bad, yes, I read them each as having two 4ohm coils. The JBL diagram left a bit to be desired, IMO. ;) And a double yes, thought U was talking...
Golden15
Golden15
Galloway, Oh
Tehgregzor
    May 31, 2024
    May 24, 2024
