When selecting fuses do you use the rated power of what you are using or the overall rated power of the amp. Example: Rater power at 1 ohm is 2500 RMS and at 2ohm it is 1250 RMS. My setup will be at 2 ohm. Do I use the 2ohm or 1ohm Rating to select a fuse.
