fuse question
1st good luck finding a 3000 amp fuse //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
2nd you will just allow more amperage to pass through that wire. i suppose it could blow the fuses on your amp. never happend to me though.
if your fuse is to small then you will not let enough current through as what it wants to draw and they will blow fast. if your fuse is to big, you could let to much through and either blow the fuses on the amp or maybe even damage the amp. the whole point of having a fuse by your battery is to prevent any current problem as quick as you can, thats why you should have a properly sized fuse.
sue bee
rock smoker
sue bee
the deathstar
ultimate157
