fuse problem
Crzy
ok on my kenwood 8101d i changed from 4 ohm load to 1 ohm. worked awesom then cut off. thoguht battery might be dying since i was just idling, so i turned car off and charged it. then played system again and it cut off permenatly. was like ****it what now. took amp out and apart thinking i blew it since light wasnt even coming on. turns out the 40 amp fuse on it blew (little bar ones in side) what should i replace it with so it doesnt blow a gain in 5 or 10 minuts //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
replace the fuses with higher rated ones:yumyum: then see if it blows them or the amp.//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Crzy
Crzy
Doylestown, PA
neonrt
Mike Mccabe
