fuse on amps keep blowing
the 30 amp fuses on my amp keep blowing every like 20 - 30 seconds after i put in new ones what could be causing this?
make sure youre not ground out on the pos or neg wire and make sure your remote isnt grounding out as well ?....................//content.invisioncic.com/y282845/emoticons/uhoh.gif.c07307dd22ee7e63e22fc8e9c614d1fd.gif
check the wire from point a to point b and look for breaks in the protective coating and if there is look for signs of burn or arcing and tape the spot with tape, and look where the wires inter the amp and makesure you dont have loose strands touching other wires in the same area
LGA
LGA
batavia, new york
LGA
Mike Mccabe
