fuse help
shouldnt cuz there shouldnt be any power going to it... if the fuse blows that means u are grounded out some where OR ur fuse in there is too weak OR there was a power surge
check your grounds. make sure they are solid and secure... then look at the fuse to see if its blown.. if u cant tell go to Shucks or Walmart and get a $3.50 fuse tester and test the fuse...
what amp and size of power cable are you using???
just so u know the fuse is what transfers the power through the fuse holder ... fuse blows power stops... just in case u didnt know that
hemplaax
hemplaax
ga
brady-lamb-ctfb
