fuse/electircal system diagnosis
loudlittlefvkus
Okay, so today my subs stopped working. the first thing i did was check my fuse. a 120 amp fuse, going to a jl audio 1000/1 slash v2 amp. the fuse was kind of corroded, looked like it was burnt a little on one end (ill post pictures when my phone charges) but the fuse was not blown. then i was wondering, because i think i have a bad ground, which im about to go check out, that was the cause. can a bad ground cause that? i also had a little extra 8 gauge wire grounded from my battery to the chassis if that makes a difference in this. i went back to check my ground, and my RCAs fell loose. could that have caused the problem too? i checked my power wire and there are no breaks or melting, like i said ill post pictures of it all when my phone charges. anyone have any ideas why this might have happened?
Im building a new box starting friday so i took my system out for now until then, and im going to do a much cleaner install. that was the first install i did last fall, and over the winter i learned a lot. so i think it will be better the second time around. so my grounding was probably the issue with the fuse? i just took pictures of the fuse and ground, uploading them now
replace the fuse/block all together. for the ground, make sure when u get the new system set up, that the wire is touching bare metal. make sure its not loose either.
loudlittlefvkus
loudlittlefvkus
Michigan
robert420
AJ (ACE)
    Jun 28, 2026
