Fuse Amperage Question
kicker06
Umm, I don't pay for food
Well my mini-anl 120amp fuse and holder melted today and I need another one, this time not the mini. I am trying to decide if I should go with 150amp or 200amp fuse for the fuse holder.
My amps are connected through the same power cable to the battery. One amp has 3 40amp fuses (120amps) and my other amp has a 40amp fuse.
So 120amps + 40amps = 160amps.
Should I go with the 200 instead of the 150, since the fuses on the amps add up to 160amps?
200amps will be fine if my amps have 160amp fuses all together, correct?
BTW I am getting knukonceptz.
Most important thing you left out: What size wire are you running? It doesn't matter what the fuses are on the amp (for the most part) as you are protecting the wire and not the amplifiers.
4awg
I've had it running forever, and it was fine.
And no I am not changing it out for 2awg or 1/0.
It was a ***** to get it in the car and I am not going through that again.
Woudl you recommend 150 or 200amps?
The biggest you should be running with 4 gauge should be 125 to be on the safe side...
But you can still squeeze in a 150 amp fuse and be alright If you wanna live on the wild side. 200 amps for 4 gauge is out of the question.
4awg
150amp is already over the limit, and as ^ said, 200 is out of the question. How long of a 4ga run do you have?
Upgrading your wiring or running a second 4awg is the only thing I would do...
kicker06
kicker06
Atlanta & South Carolina
Duke
Mike Mccabe
