Full Range Class D amplifier
OK I am new at this what do you mean run at full range. I thought class D amps were for subwoofers. Does this mean you run your mids and high with kind of amp? Soryy if I sound like an idiot...
Best application for them is in a situation where you want the least amount of current draw/highest efficiency plus the wow factor of having a highly efficient full-range amp. They are commonly known as Class T, or Tripath, as Tripath Technologies were the first to pioneer the full range Class D amp, and to produce the technology (Digital ICs) for it. They are true digital amps, unlike the misconception that Class D amps are digital. I believe that the first true Class T amps were the Blaupunkt PA series, released in 2002 (IIRC). They are amazingly small amps. Amazingly expensive as well.
My Arc 1500D is a class T and I recall it being released prior to 2002- actually theres a documented review of it on 6/01- plays 20hz- 20khz
Not saying it was the first....but that date seems off perhaps
The full-range Class D is not a Class D, but a Class T. It uses digital circuits to amplify more efficiently.
Incorrect
Full range class D amplifiers have been out long before the Tripath chip was even stable to 100w, let alone the current 1kW + you see from them these days.
The ONLY reason class "D" has been associated with 'subwoofer amplifiers' is because of the way the current market designs them.
Switching frequency of the supply for class D's is the limitation of the high end of the bandwidth. It's cheaper for manufacturers to build a slower switching supply and put it in their 'subwoofer' amplifier than to build a higher switching supply and have a 'full range capable' unit.
Class T is NOT a class D full range amplifier. It never has been, it never will be.
The amplifier stage in a Tripath unit still uses analog components. Therefore digital is simply just a misnomer like it is for the class D.
Those "high output" tripath models out today use a tripath driver, similar to this one here - and still use output transistors to generate all that power potential.
Full range Class D's is hardly a new concept.................
And I'm positive I've repeated myself on this very subject at least once...
I don't understand how this falsehood keeps getting regenerated.
Backtracking and actually researching shows the two topologies are not the same and that full range class D's have been around since the '70s.
Yeah that CD-case sized one made by Xtant. (Waste of money in my opinion). Yes I was off with that date, based on some quick googling, it looks like the first Tripath chips were starting to be integrated into car amplifiers around 1998. The TA2022 which is used in car audio applications consists of three main operational blocks, the signal processor, MOSFET driver, and power MOSFETs. You are absolutely right, I neglected to mention that the only digital component is the signal processor, which operates from a 5V CMOS. Of course the power amplification components are still analog. More info at www.tripath.com/audio.htm
Now if they could only increase power output levels, and lower costs, we'd all be swithing to Class T amplifiers.
Cathlock
Cathlock
Utah
EFFENDI
