Sold FS: Wires, Fi Sub, Misc. stuff.
boomzilla
Got 'Roids?
There Will Be Pics Later Today or Tonight! I am located in 33756 to make shipping quotes for you guys easier. Will only accept trades for two 10'' re sx's, or anything close to them. Thanks!
First is a 12'' Fi BL Fully loaded. Don't know what's making the noise, it plays perfectly, I've e-mailed Fi and they said a new dustcap should fix it. I have proof of those e-mails in my yahoo account. Dual 1 ohm coils, very good condition except the motor has been oxidized on the metal parts. On the motor's mag's there's writing, I guess RX ZILLA used to own this. $205 shipped.
Second is a box of wires $70 shipped for the whole box. Most wires have terminals, some don't. I will get exact lengths of each run and pics, but for right now I have:
ALL WIRE IS IN INCHES UNLESS STATED.
1/0 Audiopipe blue wire (4 pcs.): 16 1/2'', 14 1/2'', 25 1/2'', 31''
4g Audiopipe red wire (7pcs.): 29'', 45'', 9 1/2'', 9 1/2'', 21 1/2'', 23'', 30''
2/0 Black Welding wire (3 pcs.): 37'', 31'', 10 1/2' feet.
1/0 KnuKonceptz blue KLM wire (2pcs.): 36 1/2'', 27''
1/0 KnuKonceptz white KLM wire (4 pcs.): 21 1/2'', 32'', 25 1/2'', 39''
1/0 KnuKonceptz blue Kollosus wire? (2 very small pcs.): 6 1/2'', 7''
1/0 Welding wire grey (6 pcs.) (very short runs for batteries, or big 3 grounds): 15'', 16'', and 14''
2g Battery Post wire to ground clear (1 pc.): 16''
1/0 Q Power wire red (1 pc.): 16''
Third are distro blocks. One is a Stinger 2 1/0 in and 4 4g out. Has all set screws and mounting base. One 1/0 input has been drilled out bigger to fit some Hyperflex in there. The other distro is unbranded, 1 1/0 in and 4 8g out. 1 set screw is missing on the 8g out side, and there is no plastic cover, only mounting base. $20 shipped for both
Fourth is a Amp Rack I made for a Kicker ZX1000.1 not fancy as hell or anything, but looks cool nonetheless. Spraypainted flat black, no clearcoat, just paint to MDF. Basically made to look as if the amp is floating. Will look pretty clean with an '08 Kicker on it though, as well as the '06's. You could cut a hole in the back for a PC fan for extra cooling and wouldn't be seen.
$15 shipped
Bump! I Have count and measurements of all pieces of wire, and to make things easier I've listed the measurements, colors, and brand of each peice of wire, in my first post.
boomzilla
Got 'Roids?
boomzilla
Florida
boomzilla
