FS : Used Sundown Audio SAZ-3500D Amplifier
SkarAudio
1. Product:
Got this amplifier in on our trade in program. Tested and it works just fine. Please see the rest of description / pictures below.
2. Specs:
From woofersetc.com >>
Max power, 1 ohm mono
7000W x 1CH
RMS power, 2 ohm linkable/dual mono
7000W x 1CH
RMS power, 1 ohm mono
3500W x 1CH
RMS power, 2 ohm mono 1750W x 1CH
RMS power, 4 ohm mono
750W x 1CH
Signal to Noise Ratio >90dB
Low pass frequency crossover 35Hz~300Hz
Subsonic filter 10Hz~60Hz
Bass boost @ 45Hz 0~6dB
Phase shift control 0~180 degree
Frequency response 10Hz~350Hz (+/- 1dB)
T.H.D @ 4 ohm
Efficiency @ 4 ohm 86%
Fuse rating 300A (external type fuse)
Input Sensitivity 200mV to 6V (+/- 5%)
Dimensions 252(W) x 53(H) x 660(L)mm
3. Description/Condition:
Used.
Mechanically this amplifier works without any problem and performs great. Cosmetically if you look at the picture the RCA's are bent inwards and is just a cosmetic flaw, otherwise the amplifier is in good condition and comes with original box. I tested it and it works 10/10 as I said and does not effect performance.
4. Price: :
$800 Shipped OBO.
5. Pictures:
SkarAudio
SkarAudio
Florida
Amkbeastly
