FS/T Rockford 6.5" Components Cheap
  • 4
dross93ranger
Rockford Fosgate Prime R1652-S 6.5" Components
Like New - Installed for 2-3 months and then upgraded. These speakers sound great and do not need amplified, so these are great for your girlfriends car or daily driver!
Comes with mids, tweeters, speaker grilles, and all tweeter mounts. I also have the original box, but not the cardboard that was inside of it. The crossovers are built into the speaker.
6-1/2" 2-way Prime Series Component System
Power Handling:
Peak: 160 watts per set / 80 watts each side
RMS: 80 watts per set / 40 watts each side
1/2" Mylar balanced dome tweeter with an in-line crossover delivers crisp high frequency response
Easy installation of flush, surface, or angle mount
Mica injected polypropylene cone for extended frequency response and accommodates direct OEM installation
Foam surround allowing fluid movements for accurate sound reproduction
High quality speakers perfect for replacing original factory equipment
Stamped steel basket
Frequency response: 55 - 20,000 Hz
Crossover Frequency: 12,000 Hz
Sensitivity: 89 dB
Impedance: 4 Ohm
Grilles and hardware included
Rockford Fosgate PRIME R1652-S 6-1/2" Component Car Speakers
$45 shipped OBO, please make offers so I'm not sitting on these for months. Also I would trade for a decent equalizer (Modern one with line driver preferred)
580
The surprise wasn’t that they didn’t offer one…it’s how much engineering went into making it easily replaceable, and then not offering one. Maybe...
Thanks ya. Just pulled the trigger on the 1500BDCP because of the constant power that RF developed to help with the ohm rise.
966
I would pull it and bench test it with a 12v battery. Ive had Bulbs burn out in the past and the amplifier works excellent. They will burn out at...
dross93ranger
dross93ranger
Maysville, KY
kramer_212
    May 12, 2024
Brendon Jenness
    May 11, 2024
