Sold FS/T: 2 Eclipse Amps - EA3532 or XA5000
whitedragon551
Moderator
Reason I say EA3532 or the XA5000 is that what ever one sells first Ill use the other. I will only sell one of these amps so take your pick. I currently use the XA5000 for daily, but can have it out in a day.
I just bought the EA3532 and have some things I want to finish with my install before winter gets here so its up.
1. Product:
Eclipse XA5000
2. Specs:
Eclipse XA5000
Manual can be downloaded here:
XA5000 Manual
3. Description/Condition:
Has some very light surface rubs that can only be seen in the right light. To the ***** eye is perfect.
Internals have never been repaired as far as I can tell.
A very nice under rated amp. The XA2000 is rated for 300@4 bridged, but benched doing 380@4 with clean power.
Heres a nice little review for a comparison:
XA2000 Review
4. Price:
$240 shipped/OBO.
Im looking for 18sqft of MLV, 18sqft of CCF, and 20' of Extruded Butyl Rope (EBR)
Anything else just offer. I need to move this fast.
5. Pictures:
In the pictures the scuffs look worse than they are. Flash tends to do that.
XA5000 pictures by whitedragon5515 - Photobucket
1. Product:
Eclipse EA3532 4/5 Channel Amp
2. Specs:
* ChannelFlex Crossover
* Adjustable High-Pass Frequency (50–200Hz for Front)
* High-Pass Frequency (120Hz for Rear)
* Adjustable Low-Pass Frequency (50–200Hz for Subwoofer)
* High-Current, High-Speed Output Devices
* High-Efficiency, High-Energy MOSFET Power Supply
* Audiophile Grade Component Selection
* Intelligent 7-Way Discrete Protection Circuitry
Amplifier Type: Multi Channels
Bridgable: Bridgable
RMS Power at 4 Ohms: 40 W x 4 + 120 W x 1
RMS Power at 2 Ohms: 60 W x 4 + 120 W x 1
Performance
Frequency Response: 20 Hz - 20000 Hz
Signal to Noise Ratio: 105 dB
Crossover / Equalizer
Bass Boost: Without Bass Boost
Low - Pass Frequency: 50 Hz - 200 Hz
High - Pass Frequency: 50 Hz - 200 Hz
Other Features
Input Voltage: 13.8 volt
MOSFET Circuitry: Yes
Dimensions
Width: 15.75 in.
Depth: 10.82 in.
Height: 2.04 in.
Eclipse EA3532 Manual Pg10
I described this as old school not because of age, but because of age in comparison to Eclipse's amp lineup. This was among some of the first Eclipse amps ever made.
A few small knicks here and there and a few surface scratches. This thing is in great condition for its age. Id give it a solid 9/10 physical and 10/10 mechanical.
From what I can tell its never been repaired. The warranty label was still intact when I got the amp. I broke it to make sure the insides were in one piece after I received it from USPS prior to testing.
This amp was made circa 2003 according to the manual print date.
All I can say is that this thing is very very under rated and pure SQ.
4. Price:
$140 shipped/OBO or entertaining trades or trades + cash on your end. I have no cash to add on top.
5. Pictures:
I also have amp gut pictures. I also have taken close ups of the minor defects in the heat sink.
Eclipse EA3532 pictures by whitedragon5515 - Photobucket
Is there a measurable spec on the sound quality? THD or something? I like the age, I'm running stuff from the same kinda era.
Which one? I posted a review for an XA2000 which is a smaller amp from the same series as the XA5000. Its a class D, but in the review its stated that its just as clean as your class A/B. I would chalk it up to the ICEPower technology by Bang and Olufsen.
As for the EA3532 THD at 2ohm stereo is .008%, THD at 4 ohm stereo is .004%, and THD at 4 ohms bridged is rated at .008%. S/N ratio is 105%. Higher the percentage the less noise it will introduce into the system. 105% is pretty high. The highest I saw prior to this was right around 100% from a HU or external EQ.
I meant is there a spec that is best used? I have a couple of amps that *say* 102% S/N but I'm not 100% sure on their accuracy. Couple of older Planet Audio amps.
I'm confused though, why is the other amp more expensive? It has lower S/N and higher THD
The XA5000 is a class D, The EA3532 is a class A/B. As far as prices go thats their market value. I believe the XA5000 was somewhere around MSRP somewhere around $6-$700 BNIB. The EA3532 was MSRP around $300 or so.
well the 3532 sounds about 10x as good for SQ just will take a bit more power to run. Gonna see if I can find a way to work something like that into my system, hold on
It'd be right around enough power for my front speakers, if you had a pair of the 3532s I'd get an amazing active setup in front //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Except the amp is extremely under rated. I compared the sub channel at 2 ohms to my XA5000 which does 420@2 and also under rated. The EA3532 kept right up and is only rated for 120@2 on the sub channel.
Except I'm currently running at 150x2 @ 4 ohms. To go active I'd want about 150 watts to each channel still, and I'm pretty sure the amp isn't underrated to the point it'll put out 150x4 @ 4 ohms, but a pair would let me run each of them bridged to 120x2 @ 4 ohms which would be plenty enough when accounting for underrating. Or I could use an amp like the EA3532 on the driver's side for active, and use my old one for the passenger's side on active. That could actually work.
whitedragon551
Moderator
whitedragon551
IL
whitedragon551
