Sold FS/T: 2 Eclipse Amps - EA3532 or XA5000
whitedragon551
Moderator
Reason I say EA3532 or the XA5000 is that what ever one sells first Ill use the other. I will only sell one of these amps so take your pick. I currently use the XA5000 for daily, but can have it out in a day.
I just bought the EA3532 and have some things I want to finish with my install before winter gets here so its up.
1. Product:
Eclipse XA5000
2. Specs:
Eclipse XA5000
Manual can be downloaded here:
XA5000 Manual
3. Description/Condition:
Has some very light surface rubs that can only be seen in the right light. To the ***** eye is perfect.
Internals have never been repaired as far as I can tell.
A very nice under rated amp. The XA2000 is rated for 300@4 bridged, but benched doing 380@4 with clean power.
Heres a nice little review for a comparison:
XA2000 Review
4. Price:
$240 shipped/OBO.
Im looking for 18sqft of MLV, 18sqft of CCF, and 20' of Extruded Butyl Rope (EBR)
Anything else just offer. I need to move this fast.
5. Pictures:
In the pictures the scuffs look worse than they are. Flash tends to do that.
XA5000 pictures by whitedragon5515 - Photobucket
1. Product:
Eclipse EA3532 4/5 Channel Amp
2. Specs:
* ChannelFlex Crossover
* Adjustable High-Pass Frequency (50–200Hz for Front)
* High-Pass Frequency (120Hz for Rear)
* Adjustable Low-Pass Frequency (50–200Hz for Subwoofer)
* High-Current, High-Speed Output Devices
* High-Efficiency, High-Energy MOSFET Power Supply
* Audiophile Grade Component Selection
* Intelligent 7-Way Discrete Protection Circuitry
Amplifier Type: Multi Channels
Bridgable: Bridgable
RMS Power at 4 Ohms: 40 W x 4 + 120 W x 1
RMS Power at 2 Ohms: 60 W x 4 + 120 W x 1
Performance
Frequency Response: 20 Hz - 20000 Hz
Signal to Noise Ratio: 105 dB
Crossover / Equalizer
Bass Boost: Without Bass Boost
Low - Pass Frequency: 50 Hz - 200 Hz
High - Pass Frequency: 50 Hz - 200 Hz
Other Features
Input Voltage: 13.8 volt
MOSFET Circuitry: Yes
Dimensions
Width: 15.75 in.
Depth: 10.82 in.
Height: 2.04 in.
Eclipse EA3532 Manual Pg10
I described this as old school not because of age, but because of age in comparison to Eclipse's amp lineup. This was among some of the first Eclipse amps ever made.
A few small knicks here and there and a few surface scratches. This thing is in great condition for its age. Id give it a solid 9/10 physical and 10/10 mechanical.
From what I can tell its never been repaired. The warranty label was still intact when I got the amp. I broke it to make sure the insides were in one piece after I received it from USPS prior to testing.
This amp was made circa 2003 according to the manual print date.
All I can say is that this thing is very very under rated and pure SQ.
4. Price:
$140 shipped/OBO or entertaining trades or trades + cash on your end. I have no cash to add on top.
5. Pictures:
I also have amp gut pictures. I also have taken close ups of the minor defects in the heat sink.
Eclipse EA3532 pictures by whitedragon5515 - Photobucket
Hmmm, can the X5000 sub channel do 2Ohms? If so I could do some cash and the 36401 that you want
Does 420@2 on the sub channel. Also under rated. The XA2000 is supposed to do 300@4 bridged, but did 380/390@4 bridged just to give you an idea.
Unfortunately I only wanted your amp to add to my collection of Eclipse gear. I have some stuff I need to finish up before winter sets it.
whitedragon551
Moderator
whitedragon551
IL
whitedragon551
