FS: Sundown Audio SAZ-3000D
BreakingBad
Banned
1,321
pittsburgh
Used for roughly 2 1/2 years, I never abuse any of my stereo equipment. Moved from an SUV to a car, so due to amp size and the fact I do not need this much power, out she goes! Amp working flawlessly with no problems. Sold as-is/no returns as this is a used equipment sale.
SPECIFICATIONS:
Double Sided Through Hole Epoxy PCB
Efficiency : 86% @ 4 ohm, at 100Hz
24dB/Oct Variable Crossover
Multi-Way Protection Circuitry
(Thermal/Over Current/Speaker Short/Speaker DC Protection)
Variable Subsonic Filter
Variable Bass Boost
Variable Low Pass Filter
Variable Phase Shift
Zero(0) Gauge Power Supply Connectors
Tested Voltage & THD : 14.4V & Less than 1% THD
Operating Voltage : DC 10V~18V
Digital Class-D Linkable Mono Block Amplifier
1 Ohm Stability
RCA Line Input and Master Output
24dB Octave Crossover Slope
Wired Remote Controller
MSRP $1549 USD
1 ohm mono 3000W x 1CH
2 ohm mono 1600W x 1CH
4 ohm mono 800W x 1CH
Signal to Noise Ratio >90dB Low pass frequency crossover 35Hz~300Hz Subsonic filter 10Hz~60Hz Bass boost @ 45Hz 0~18dB Phase shift control 0~180 degree Frequency response 10Hz~350Hz (+/- 1dB) T.H.D @ 4 ohm
$450 + shipping (to be calculated)
Shipping via UPS GROUND. Buyer pays shipping + declared value fee.
Is American Bass better then Mmatts? Again I'm in love with quality and smoothness with alot of power and so far I'm Does the ABs have better...
Some of the NVX stuff seems alright, but the amps, especially the higher end ones, they seem suspect and sometimes show stats that straight up say...
13
4K
BreakingBad
Banned
BreakingBad
pittsburgh
sleazebagger
GoldCountryCA
    May 5, 2024
GoldCountryCA
    May 5, 2024
