Sold FS: Sub, box, 2 amps, amp rack, cap
breakinthebeats
Alright people...I am selling a MTX 9512-44, Kicker ZX1000.1, Infinity Reference 7541a, 2 farad Tsunami cap, box, and amp rack...everything is in excellent condition. I had this set up in a 2004 oldsmobile alero. I recently bought a single cab S10 and this equipment won't fit, so I have to get all new stuff...which sucks because I was very very pleased with this set up. I am asking $1200 o.b.o shipping included. Only serious offers need to apply please.
Here are the specs
Sub
MTX 9512-44
Dual 4ohm
Frequency Response - 31-150hz
RMS watts - 1000
Voice Coil - 4"
Magnet weight(oz) - 260
Kicker amp
Amplifier Class N/A
Number of Channels 1 - Mono
RMS Power (4 ohms) 500 watts x 1 channel
RMS Power (2 ohms) 1000 watts x 1 channel
RMS Power (1 ohm) Not Stable
Bridged RMS Power Not Bridgeable
Peak Power Output N/A
Minimum Impedance Unbridged 2 ohms
Minimum Impedance Bridged Not Bridgeable ohms
THD at Rated RMS Power
Speaker Level Inputs Yes
Preamp Outputs Yes
Built-in Crossover Yes - LP
High-Pass Crossover Frequency N/A
Low-Pass Crossover Frequency 50 - 200 Hz
Subsonic Filter Defeatable @ 25Hz
Signal-to-Noise Ratio 95 dB
Channel Separation N/A
Bass Boost 0 - 18 dB
Bass/Gain Remote Yes
Fan Cooled N/A
Fuse Rating 100A
Infinity amp
4-channel car amplifier
111 watts RMS x 4 at 4 ohms (139 watts x 4 at 2 ohms)
278 watts RMS x 2 bridged output at 4 ohms (4-ohm stable in bridged mode)
front and rear variable high-/low-pass filters (32-320 Hz, 12 dB/octave)
variable bass boost (0-12 dB at 50 Hz)
MOSFET power supplies
CEA-2006 compliant
Tri-way capable (Tri-Way Crossover required)
preamp- and speaker-level inputs
preamp outputs
8-gauge power and ground leads with a 60A fuse recommended — wiring and hardware not included with amplifier
fuse rating: 30A x 2
16-3/8"W x 2-11/16"H x 12-1/8"D
breakinthebeats
breakinthebeats
Acworth, GA
dpom
