FS : Rockford Fosgate T600-2 2 Channel Amplifier
  • 1
SkarAudio
Florida
1. Product:
Rockford Fosgate T600-2 2 Channel Car Amplifier
Got this in via our trade in program - which is why we are selling it - incase anyone was wondering.
2. Specs:
Power Series Compact 2-Channel Amplifier
RMS Power Output:
4 ohms: 200 watts x 2 channels
2 ohms: 300 watts x 2 channels
Bridged, 4 ohms: 600 watts x 1 channels
CEA-2006 compliant
Dynamic Thermal Management cooling system
Differential Input circuitry eliminates hum
Variable high- and low-pass filters (50-500 Hz, 24 dB/octave)
Variable bass/treble boost (0-18 dB at 45 Hz, 0-12 dB at 12k Hz)
Optional remote bass/treble boost
Class AB amplifier design
MOSFET power and output stages
Preamp inputs and outputs
4-gauge power and ground leads and a 150-amp fuse recommended — wiring and hardware not included with amplifier
No on-board fuses — when installing multiple amps in a system, an additional 150-amp in-line fuse between the distribution block and the amplifier is recommended
Frequency Response: 20 Hz - 20 kHz
Dimensions: 9-5/8"L x 13-11/16"W x 2-3/16"H
3. Description/Condition:
Used but tested working and cosmetically is in great condition as well. See the detailed images below for more on the condition.
4. Price: :
$170 Shipped in the lower 48 states via UPS ground, OBO. First come first serve. Our PayPal email address is the same as in my signature. Ships same day payment is made!
5. Pictures:
I would pull it and bench test it with a 12v battery. Ive had Bulbs burn out in the past and the amplifier works excellent. They will burn out at...
roger that, just got one from sonic electronix for $189. thanks for the help
18
Maybe ask RF tech support. I wasn’t able to find that either. Sonic electronics and Crutchfield just use the same description as the rf site. True...
After looking at amazon for kicker q product details, it showed rms of 1200@2ohm If you’re at 2ohm you’re not feeding it enough power. At 1ohm...
SkarAudio
SkarAudio
Florida
SkarAudio
Brendon Jenness
    May 11, 2024
RedRyder18
    May 11, 2024
