SOLD FS: Rockford Fosgate Punch 45, 25 to life Edition
  • 6
jonny101abc
SOCAL Stang-Man
1. Product:
2. Specs:
* 2-channel car amplifier
* 22.5 watts RMS x 2 at 4 ohms (35 watts x 2 at 2 ohms)
* 70 watts RMS x 1 bridged output at 4 ohms (4-ohm stable in bridged mode)
* variable high- or low-pass filters (40-400 Hz at 12 dB per octave)
* wired remote bass boost (0-18 dB at 45 Hz)
* CEA-2006 compliant
* heavy-duty power and speaker terminals
* custom-designed TO-247 MOSFET power supply and output stage for more clean headroom
* preamp outputs
* fuse rating: 30A x 1
* 10-gauge power and ground leads recommended — wiring and hardware not included with amplifier
* 11-3/4"W x 2-5/8"H x 11-1/4"D
lost the birthsheet for this amp, but the birthsheet for the other punch 45 i have says cloase to 150 watts per channel into 4ohms stereo
3. Description/Condition:
new, never powered or mounted, lost box, manual, and birthsheet
4. Price: :
$180 shipped and insured or OBO
5. Pictures:
Uploaded with ImageShack.us
That "259 watts into 2ohms" is a total wattage for both channels.
I bought a MINT one off eBay for $125 shipped, although the amp is worth your asking price, it may be a little difficult to get here. You MAY get $150 on eBay, but it depends on the day it ends and how many peeps are fighting for it. Just for comparison, I got a pre-prod Punch 75 "25 to life" directly from RF (highdesertaudio) for $180 just a few weeks ago.
Great amp, underrated and very under-appreciated! GLWS!
After looking at amazon for kicker q product details, it showed rms of 1200@2ohm If you’re at 2ohm you’re not feeding it enough power. At 1ohm...
I would pull it and bench test it with a 12v battery. Ive had Bulbs burn out in the past and the amplifier works excellent. They will burn out at...
roger that, just got one from sonic electronix for $189. thanks for the help
18
Maybe ask RF tech support. I wasn’t able to find that either. Sonic electronics and Crutchfield just use the same description as the rf site. True...
jonny101abc
SOCAL Stang-Man
jonny101abc
San Diego Punks!
jonny101abc
