Sold FS: Rainbow 2 channel amp $195 shipped
FoxPro5
Causal wanderer
Like new. Used for about 2 months. There is a tiny dent in the top of the heatsink that isn't really noticable unless you look at the right angle. I'd give it a 9/10 cosmetic, 10/10 functional.
Comes with original box, manual, etc.
There are no controls on this amp! Only gain. I does have dip switch that allows you to select between a 5.5v and 1v input sensitivity.
http://car.rainbow-audio.de/products/details.php?lan=2&pro=3&lin=19&art=271026
Specifications:
KW 2270
2 Channel
Part number: 271026
Peak output power: 2 x 270 Watt
Output power RMS at 4 Ohm: 2 x 135 / 1 x 450 Watt
Output power RMS at 2 Ohm: 2 x 230 Watt
Load impedance: 2 x 4/2 | 1 x 8/4 Ohm
Total distortion factor (THD+N): 0.02 % @ 100Hz/1W
Signal-to-noise ratio (S/N): > 85 dB A-weighting
Frequency response at -3 dB: 10 - 50.000 Hz
Damping factor at 4 Ohm: > 200
Input sensitivity line input: 1 / 5.5 V
Operating voltage: 11 - 18 V DC
Input current / Peak input current: 51 A
Dimensions (WxDxH): 376x273x59 mm
Weight: 4.2 kg
Certification: E11 10R-023307 / CE
$195 shipped in the US. Retail is $430 USD.
Link fixed.
Here's the pics:
FoxPro5
Causal wanderer
FoxPro5
3 octaves higher
FoxPro5
slater
    Oct 4, 2025
    Oct 4, 2025
