FS: New Sundown Audio SAE-1000Dv2
$LICK CALIFA$
Not Far!
Digital Class-D Linkable Monoblock Amplifier
MOSFET PWM Power Supply
1-Ohm Stable Load
24dB/Oct - Variable Low Pass Filter
24dB/Oct - Variable Subsonic Filter
12dB/Oct - Variable Bass Boost
180 Degree Variable Phase Shift
4-Way Protection Circuit (Thermal, Voltage Speaker Short and DC Offset)
Wired Remote Control
Rated Power Output (Tested Voltage 14.4 Volts):
RMS Power 2-Ohms Linked: 2000W
RMS Power 1-Ohm Mono: 1000W
RMS Power 2-Ohm Mono: 500W
RMS Power 4-Ohm Mono: 250W
Low Pass Frequency Crossover: 30Hz - 250Hz
Subsonic Filter: 10Hz - 50Hz
Bass Boost - 45Hz: 0-12dB
Phase Shift Control: 0-180 Degree
Frequency Response: 10Hz - 250Hz
Input Sensitivity: 6 - 0.2 Volts
Signal Noise Ratio: >100dB
THD 4-Ohms:
Efficiency 4-OIhms: 86%
Recommended Fuse Rating: 40A x 3
Dimensions: 13.1" L x 8.5" W x 2.3" H
Literally brand new, never been mounted. I got it in a trade and only powered up to make sure it worked.
Comes with box, manual, 2 sundown stickers, wired remote, high level adapter and extra fuses.
Pics below show condition.
2nd pic shows green power led on
$260 shipped obo lower 48 - cash is king but pm trade offers
Is American Bass better then Mmatts? Again I'm in love with quality and smoothness with alot of power and so far I'm Does the ABs have better...
Some of the NVX stuff seems alright, but the amps, especially the higher end ones, they seem suspect and sometimes show stats that straight up say...
13
5K
$LICK CALIFA$
$LICK CALIFA$
Not Far!
$LICK CALIFA$
    May 16, 2024
    May 16, 2024
