FS: New Sundown Audio SAE-1000Dv2
$LICK CALIFA$
Digital Class-D Linkable Monoblock Amplifier
MOSFET PWM Power Supply
1-Ohm Stable Load
24dB/Oct - Variable Low Pass Filter
24dB/Oct - Variable Subsonic Filter
12dB/Oct - Variable Bass Boost
180 Degree Variable Phase Shift
4-Way Protection Circuit (Thermal, Voltage Speaker Short and DC Offset)
Wired Remote Control
Rated Power Output (Tested Voltage 14.4 Volts):
RMS Power 2-Ohms Linked: 2000W
RMS Power 1-Ohm Mono: 1000W
RMS Power 2-Ohm Mono: 500W
RMS Power 4-Ohm Mono: 250W
Low Pass Frequency Crossover: 30Hz - 250Hz
Subsonic Filter: 10Hz - 50Hz
Bass Boost - 45Hz: 0-12dB
Phase Shift Control: 0-180 Degree
Frequency Response: 10Hz - 250Hz
Input Sensitivity: 6 - 0.2 Volts
Signal Noise Ratio: >100dB
THD 4-Ohms:
Efficiency 4-OIhms: 86%
Recommended Fuse Rating: 40A x 3
Dimensions: 13.1" L x 8.5" W x 2.3" H
Literally brand new, never been mounted. I got it in a trade and only powered up to make sure it worked.
Comes with box, manual, 2 sundown stickers, wired remote, high level adapter and extra fuses.
Pics below show condition.
2nd pic shows green power led on
$260 shipped obo lower 48 - cash is king but pm trade offers
$LICK CALIFA$
$LICK CALIFA$
Not Far!
$LICK CALIFA$
