Sold FS: My Whole System
djXternal
Well I sold My Eclipse and bought a Jeep, so I will not be needing any of this audio equipment I have around here anymore, all the equipment listed has only been used for 2-3months unless otherwise stated.
All prices are shipped in U.S. and OBO
Specs for Items will be copied straight from manufacturer specs
Alpine MRP-F250 130$
-4 Channel Car Amplifier
-Frequency Response: 10Hz - 50kHz (+0/-1dB)
-40 Watts RMS x 4 at 4 ohms
-100 watts RMS x 2 bridged output at 4 ohms
-2, 3 or 4 channel output
-Variable High Pass/Low Pass Filter (50-400 Hz, 12 dB octave)
-Tuned Bass EQ (0-12 bass boost at 50Hz for channels 3 & 4)
-Subsonic Filter (24dB at 15 Hz for channels 3 & 4)
-MOSFET power supply
-Tri-way capable (Tri-Way Crossover required)
-CEA-2006 compliant
-STAR Topology
-Speaker and pre amp level inputs
-Gold Plated screw terminals
-Fuse rating: 25A x 1
-10G Power and ground leads recommended-wiring and hardware not included with amplifier
-9 1/4" W x 2 3/8" H x 9 1/2" D
-10k Ohm input impedance
-4 or 2 ohm Bridged Speaker Impedance
-Low Frequency Response: 10 Hz
-High Frequency Response: 50000 Hz
-RMS Power range: 50-400 Watts
-4 Channels
-Built in crossover
-Channel Separation
Crossfire VR-600D 300$
-Bridgeable 2 channel amplifier
-150W x 2 RMS, 600W Max.
-Switchable 6dB boost at 45Hz
-Variable Highpass/Lowpass Crossover from 50 to500Hz
-Low level (RCA) or High level (speaker) Inputs
-Nickel plated connectors
-5 way protection circuit
-2 ohm stable
-9.3"W x 2.1"H x 15"L
Bazooka ELA300.1 80$ (used for around 8 months, then replaced by crossfire) (SOLD)
-Power Output: 300W
-Frequency Response: 20-250Hz
-Fuse 60 Crossover
-Protection Thermal, Short Circuit, Overload
-Max Power Output: 500W
-Power @ 4 OHM: 300W
-Power @ 2 OHM: 500W
-Signal To Noise Ratio: 115
-Battery Voltage Range 10.5-14.4 volt
-Bass EQ
JL Audio TR650CSi $100
-6.5-inch (160 mm) Woofer
-0.50-inch (12 mm) Tweeter
-Grilles Included.
-Perfect fit in many U.S. and European vehicles.
-50W Continuous Power Handling
-Rec. Amp Power: 10 - 75 Watts
-91.0 dB Efficiency @ 1W/1m
-FR: 59 Hz - 22 KHz @ 3 dB
Verge VMP508 $40 (used for almost a year)
AM/FM/CD/CDC/MP3 Receiver
with Dtachable Faceplate
Power Output: 13W RMS x 4 channels
into 4 Ohms
Signal to Noise Ratio: 70dBA (reference: 1 Watt into 4 Ohms)
Dynamic Power: 26 Watts x 4 Channels into 4 Ohms
Frequency Response: 20Hz to 20kHz (-3dB)
ID3 Tag ompatibility
24 Station Presets
CD Changer Controller
3 Selectable EQ Curves
Auto Station Store
Subwoofer Output
Aux Input
Pre-Amp Output
Pair of Verge 6.5" 2-way Coax's $30 (used for almost a year)
25W RMS @ 4 Ohms
Pair of Verge 6"x8" 2-way Coax's $30 (used for almost a year)
30W RMS @ 4 Ohms
Pair of 6.5" OEM Mitsu Eclipse Speakers $15
No Idea On Specs
Unknown HU $20
AM/FM/CD, Possibly MP3 (but unsure)
3 Stinger Power Distro Blocks
-- 2x 0/1awg --> 3x 4awg Fused Block w/ 3 60amp fuses (40$)
-- 2x 0/1awg --> 3x 4awg Non-Fused Block ($30)
-- 2x 4awg --> 3x 8awg Non-Fused Block ($30)
2x JL Audio 10w0 in Custom Fiberglass Enclosure (SOLD)
For a 2nd Gen Eclipse, Everything together available for Local pickup (220$)
Just the Subs ($85 per Sub)
Remember all Prices are OBO within reason, I also have some stinger power cable in both 0/1awg and 4awg unsure of the lengths I have currently but if interested let me know
PICS: http://s90.photobucket.com/albums/k280/djXternal/For%20Sale/
djXternal
djXternal
Tampa, FL
djXternal
