FS: Monster Cable I404, I402, I400 and Y-spliiters RCA's
treylittlefield
1. Product: ^^^^^ the longer ones are 4 meters. the shorter one is .5 meters. Y-Splitters are 1 female 2 male.I paid $250+ for all of this. I will have pics of the splitters soon. Got to dig them outta the closet.
2. Specs:
I404
  • 13.12 ft. (4 meters) of 404 XLN Xtreme Series 4-Channel Audio Interconnect Cable
  • Split tip center pin for an even tighter connection and greater contact pressure
  • 8-Cut Turbine ultra-polished MirrorChrome connectors for connectivity and optimal corrosion resistance
  • Ultra-low profile Stubby connector design for hassle-free installation
  • 3-Way Time Correct windings separate high, mid and low frequency wire networks for a natural sound
  • MicroFiber dielectric for faster transients and wider dynamic range
  • PEX Dielectric for additional insulation of wire networks for reduced interference
  • XLN Xtreme technology provides 80dB noise rejection for clear sound
  • Duraflex HexMash protective jacket for easy installation and durability
I402
  • Cable Length: 13.12ft. (4 meters)
  • Color: Silver/Gray
  • Made using exclusive monster patented technologies to produce the highest class cable possible
  • Monster design improves contact pressure and lowers distortion, giving you a clearer signal transfer
  • 8-Cut Turbine Ultra-Polished MirrorChrome Connectors maximize surface area and creates higher contact mass for precision signal transfer.
  • Ultra-Low Profile Stubby Connector Design for easy installation
  • 3-Way Time Correct Windings improve clarity and accurately reproduce amplitude and phase response
  • MicroFiber Dielectric isolates individual wire networks for faster transfer
  • PEX Dielectric Prevents signal loss and provides more accurate signal transfer
  • Duraflex Hexmesh Protective Jacket minimizes friction for easy install
  • XLN Xtreme Construction provides protection against interference up to 80dB
3. Description/Condition: works fine. there are a few cuts in the rubber boot...only cosmetic they work fine. The shorter one is brand new never used. The ONLY reason i am getting rid of these are that im moving my amps and they just aren't long enough.
4. Price: : $200 shipped OBO. trades would be for longer rcas of very good quality, around 100ft of good speaker wire, techflex, jsut offer up.
5. Pictures:
This image has been resized. Click this bar to view the full image. The original image is sized 799x597.
  • Locked
Thanks for the quick rep and it was great chatting w/ you. Good luck w/ what we discussed. It rare but sometimes I stumble across odd and ends...
18
No make or model number on it? Do you have an exact picture of the rear and all its glory?
772
https://www.ebay.com/itm/263364485734?mkcid=1&mkrid=711-53200-19255-0&siteid=0&customid=link&campid=5335951755&toolid=20001&mkevt=1
treylittlefield
treylittlefield
Sand Rock, AL
treylittlefield
    May 24, 2024
