Sold FS: matching MA AUDIO amplifiers... HC4002 does 4000 WATTS x 1 @1ohm! HC504 does 50x4
MikeySpice
New York City's Finest
HC4002 - $320 SHIPPED
HC504 - $200 SHIPPED
BOTH FOR $500 SHIPPED!!
BRAND NEW: MA AUDIO HC4002 AMPLIFIER
HC Series features:
• High Current,Non-Regulated Power Supply
• Double Sided PCB
• Cooling Fan (Thermal Regulated)
• 24dB Active Slope Crossover
• 18db Variable Frequency Bass Boost
• Variable Phase Shift(180 degrees)
• VU Meters
• Line Out
• Protection Status Indicator
Specifications:
• Bass Frequency Range: 45Hz to 90Hz
• Bass Boost: 0 - 18db
• Frequency Response: +- 1dB from 10Hz to 40KHz
• Signal to Noise Ratio: > 100dB
• Input Sensitivity: 100mV to 7V
• Channel separation(AT IW): > 60dB
• Damping Factor(ATIW / 50Hz): >240
• Typical Current Draw At IDLE: 1.4Amps
Stereo Power
• Into 4 Ohms @ 13.8V DC : 2 x 400W
• Into 2 Ohms @ 13.8V DC : 2 x 700W
• Into 1 Ohms @ 13.8V DC : 2 x 1200W
• Into 0.5 Ohms @ 13.8V DC : 2 x 2000W
Mono Power:
• Bridged Into 1 Ohms @ 13.8V DC : 1 x 4000W
Recommended Fuse Size:
• HC4002: 40A x 4
Dimensions:
• 2.3" x 10.8" x 26.4" (H x W x L)
BRAND NEW: MA AUDIO HC504 AMPLIFER
Bridgeable
Tri-Mode Capable
Low Level Inputs
Bypass Line Output For Connecting Multiple Amplifiers To The Same Signal
Variable Low-Pass Filter 45- 1220 Hz
Variable High Pass Filter 100-800 Hz
Variable Bass Boost 0-18 dB
Variable Bass Boost Frequency: 45-90 Hz
Variable Phase Shift: 0-180 Deg
Variable Output Level Control
Thermal, Short Circuit & Overload Protection
VU Meters
Cooling Fan
500W X 2 Bridged 4 Channel High Current Amplifier
4 X 50 RMS @ 4 Ohm
4 X 90 RMS @ 2 Ohm
4 X 150 RMS @ 1 Ohm
4 X 250 RMS @ 0.5 Ohm
Bridged 2 X 180 RMS @ 4 Ohm
Bridged 300 RMS X 2 @ 2 Ohm
Bridged 500 X 2 RMS @ 1 Ohm
Dimensions: 11-1/2" W X 2-1/2" H X 17-3/4" L
MikeySpice
MikeySpice
New York City
audioatg
