Sold FS: matching MA AUDIO amplifiers... HC4002 does 4000 WATTS x 1 @1ohm! HC504 does 50x4
MikeySpice
New York City's Finest
HC4002 - $320 SHIPPED
HC504 - $200 SHIPPED
BOTH FOR $500 SHIPPED!!
BRAND NEW: MA AUDIO HC4002 AMPLIFIER
HC Series features:
• High Current,Non-Regulated Power Supply
• Double Sided PCB
• Cooling Fan (Thermal Regulated)
• 24dB Active Slope Crossover
• 18db Variable Frequency Bass Boost
• Variable Phase Shift(180 degrees)
• VU Meters
• Line Out
• Protection Status Indicator
Specifications:
• Bass Frequency Range: 45Hz to 90Hz
• Bass Boost: 0 - 18db
• Frequency Response: +- 1dB from 10Hz to 40KHz
• Signal to Noise Ratio: > 100dB
• Input Sensitivity: 100mV to 7V
• Channel separation(AT IW): > 60dB
• Damping Factor(ATIW / 50Hz): >240
• Typical Current Draw At IDLE: 1.4Amps
Stereo Power
• Into 4 Ohms @ 13.8V DC : 2 x 400W
• Into 2 Ohms @ 13.8V DC : 2 x 700W
• Into 1 Ohms @ 13.8V DC : 2 x 1200W
• Into 0.5 Ohms @ 13.8V DC : 2 x 2000W
Mono Power:
• Bridged Into 1 Ohms @ 13.8V DC : 1 x 4000W
Recommended Fuse Size:
• HC4002: 40A x 4
Dimensions:
• 2.3" x 10.8" x 26.4" (H x W x L)
BRAND NEW: MA AUDIO HC504 AMPLIFER
Bridgeable
Tri-Mode Capable
Low Level Inputs
Bypass Line Output For Connecting Multiple Amplifiers To The Same Signal
Variable Low-Pass Filter 45- 1220 Hz
Variable High Pass Filter 100-800 Hz
Variable Bass Boost 0-18 dB
Variable Bass Boost Frequency: 45-90 Hz
Variable Phase Shift: 0-180 Deg
Variable Output Level Control
Thermal, Short Circuit & Overload Protection
VU Meters
Cooling Fan
500W X 2 Bridged 4 Channel High Current Amplifier
4 X 50 RMS @ 4 Ohm
4 X 90 RMS @ 2 Ohm
4 X 150 RMS @ 1 Ohm
4 X 250 RMS @ 0.5 Ohm
Bridged 2 X 180 RMS @ 4 Ohm
Bridged 300 RMS X 2 @ 2 Ohm
Bridged 500 X 2 RMS @ 1 Ohm
Dimensions: 11-1/2" W X 2-1/2" H X 17-3/4" L
WHATS THE LOWEST YOU CAN SEE YOURSELF GOING ON THE HC4002
HC4002 - $320 SHIPPEDHC504 - $200 SHIPPED
HC Series features:
• Double Sided PCB
• VU Meters
• Line Out
Specifications:
Stereo Power
Mono Power:
• HC4002: 40A x 4
Dimensions:
Bridgeable
Tri-Mode Capable
Low Level Inputs
VU Meters
Cooling Fan
4 X 50 RMS @ 4 Ohm
4 X 90 RMS @ 2 Ohm
4 X 150 RMS @ 1 Ohm
hc1002:
2-channel high current amplifier
STEREO
4ohms---2x100w
2ohms---2x180w
1ohms---2x300w
0.5ohms---2x500w
MONO
4ohms---1x360w
2ohms---1x600w
1ohms---1x1000w
High current, non-regulated power supply
Double sided circuit board
cooling fan
24db active slope crossover
18db variable frequency bass boost
variable high and low pass filters
variable phase shift (180degrees)
vu meters
line out
protection status indicator
MikeySpice
MikeySpice
New York City
audioatg
