Sold FS: MA HK-4000D $500 shipped
ACT Audio
ACT AUDIO
Just recently bought this amp from NESPL. Was going to use it for everyday, but need $$$ for other AMP repairs. Pics posted on Tuesday, any questions PM me.
Here's what I got for SPECS:
Description
RMS Power @ 14.4V: 50W x 1 @ 4 Ohm - 3600W x 1 @ 2 Ohm
Details
Key Features
Brand MA Audio
Model HK-4000D
Number of Channels 1
Min Frequency Response 10 Hz
Protection Circuitry Thermal, Overload, Short Circuit
Power Supply Topology MOSFET
Input Voltage 14.4 volts
Variable Gain Control With Variable Gain Control
Signal To Noise Ratio 96 db
Features
Bass Boost With Bass Boost
Fuse Rating 2x25 AMPS
Phase Control With Phase Control
Subsonic Filter With Subsonic Filter
Remote Control With Remote Control
Output Power
Preamp Outputs 1 Pair
Peak Power Output (Watts X Channels) 800 x 1
Power At 2 Ohms (Watts X Channels) 3600 x 1
Minimum Impedance Unbridged 2 Ohms
Crossover
Built-In Crossover With Built-in Crossover
Low-Pass Crossover Min Frequency 50 Hz
Low-Pass Crossover Max Frequency 150 Hz
Low-Pass Slope (dB/Octave) 24 db
Dimensions
Height 2.71 in
Depth 25.86 in
Width 12.4in
draws around 228A under 0.5 load. Was using 2 Batcap 3000's with it, never dropped below 13.4
What the hell!!!!More like 600-700ADC@.5!:crazy:The box says right on it the thing pulls 400A's and an eletrical upgrade is required.
I would not suggest running this amp at .5 daily.It will get very hot and could lead to problems down the road.With a good electrical backing it you will get decent power at 1 ohm and be less stress on the amp.
actually clamped it only was drawing 228.......@0.5 ohm. does get hot and needs proper cooling and ventalation. Box Rise also a huge factor. Set for 1 ohm total rise and ur good.
I think you clamped it wrong then buddy. WAY wrong. That thing draws that number more like at 4 ohms and up. Not at .5 At .5 its more over 500 amps.
Dont get it wrong I have owned them. And loved owning them. But you will fry that amp running it at .5 with a lack luster eletrical back up power.
ACT Audio
ACT AUDIO
ACT Audio
Vernon, CT
audioatg
