Sold FS- Lots of misc. install stuff, Headunits, Tweeters, amp, etc
casper97ta
IM HERE FOR THE GANG BANG
I have a bunch of left over install things here. There's about 13ft of Stinger 12g speaker wire. It has some tape residue on it in a couple places but can come right off I just didnt do it. $15
Also in the pic are a set of Raptor Rca's. Never opened. They have a remote wire attached to them also and are 20ft. $15
There are 27 fuses pictured. They are the bigger ones that are used as in-lines. The amps are: 1-30a, 13-40a, 3-50a, 9-20, 1-35. SOLD!
Also in the pic are 2 anl fuses both 150a and brand new $5
A Boss distro block, 3 1/0 in and 4 8g out. The holes that are supposed to be 1/0 look a little small. Its also brand new. $10
Next up is a Head unit. Its a Kenwood model KDC-S5009 40x4 . Works perfectly. Its has some scratches and doesnt play mp3's. $50
Next up are some tweeters. I have 3 sets. First set is from the MB quart discus series. These are pretty big. I think 1.5" One works perfect the other needs the negative copper wire on the back reattached to the terminal. It should be easy I just dont do soldering. the model is QM13HX -$30
Next are a pair of cheap-*** Audiobahn tweets work perfect- $15
And a set of Focal tweets that also only one tweet works. these are from the Access component set. Tweets and crossovers $30
And I have a Treo 75.2 that doesnt power up I havent opened it up I was gonna send it to DB-r for a repair but if someone wants it I'll sell it. The repair should be cheap. $75
And finally I have a 3 way Rockwood crossover. Its silver and has rust on it. I have no use for it. It would be a good cheap crossover for someone to go active with. $20.
quote on the repair of the treo? me
I have no idea yet. I was just gonna send it in to DB-r and let him go at it. You can contact him on here or his forum DB-r.com. He's really reasonable and its a small amp so it should be fairly cheap.
man if i had the cash id take the treo //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif i want a amp to work on.
Make me an offer man, I'm flexible. I really wanted to get it fixed and use it but I'm thinking of grabbing a 75.4 to go active with.
casper97ta
casper97ta
Pittsburgh, PA
grimreper912003
