FS: Hybrid Audio Technologies - Clarus C61-2
Huckleberry Snd
Item(s) for Sale: Hybrid Audio Technologies - Clarus C61-2
Item(s) Description/Condition: Brand New - Unused
Price: $450.00
Shipping and Miscellaneous Item Information: Shipping is included to the lower 48 states. International shipping, send private message to make arrangements.
Item Pictures: - Attached
Additional info: This is a brand new pair un-unused. Please feel free to ask all questions.
Clarus System Specifications
Frequency Response50Hz-22KHz +/-3dB
Efficiency 2.83 V/ 1 meter 93.6 dB
Continuous power Handling (transient music input) 120 watts
Peak power Handling (musical transient peak power handling) 250 watts
Recommended Power Range 25-175 watts
Nominal Impedance 4Ω
Thiele/Small Parameters
Overall Diameter Φ166 mm
Mounting Depth 78.5 mm
Bolt Circle Diameter Φ156.5mm
Mounting Hole Φ143.5 mm
Recommended Minimum Highpass
Crossover Frequency (fourth order) 45 Hz
Pnom Rated Power Input (No Crossover) 60 watts
Pmax Rated Power Input (No Crossover) 120 watts
Frequency Range of midbass driver alone (not including tweeter device) 50-9,000 Hz +/- 3 dB
Mms 14.1 g
Cms 674 μM/N
BL 5.4 T*m
Voice Coil Diameter 35.5 mm
DC Resistance 3.4 Ω
Fs 50 Hz
Qms 5.527
Qes 0.532
Qts 0.485
Xmax 14mm (two way)
Vas 14.9 L
Sd 12.4692
Good Afternoon Bump!
do you have a pic of the speakers/box with a picture of your username and date in the same pciture, not seperate? also could you please post a pic of the motor? i might be interested.
This evening I will remove the speakers from the shipping box to take the pictures you are requesting. This evening I will take the pics you are requesting. Send me a personal message with your e-mail address and I will send all the pictures there.
Thanks
Thanks
just post them on here, it will help your sale if i dont take them.
Pics have been updated, let me know if you have any other questions.
Thanks
I don't think OP is going to do the deadener themself, but these are my tools for it. If its 80 degrees out, you can just leave it out and it's...
4K
Actually, I was wrong, it was to go into his 1972 Currier! The 4runner just wasn't workable and he ended up getting a high performance motor...
28
When I first started with upgrades, I purchased a harness that allowed me to add an amplifier by tapping into the factory wiring. It was a PAC...
Huckleberry Snd
Huckleberry Snd
Marietta, Ga
Huckleberry Snd
