FS: HAT L3 set & BNIB Zapco (ESB) Reference 1.1" Tweets
BlkonBlkFG
366
IL
HAT L3 set
SOLD
These speakers have been installed in my truck for appeoximately 9 months. They were bought and installed from an authorized dealer. They function perefectly. Cosmetically the only "problem" is that there is a little bit of sound deadening on the outside ring where the screws go from the install. These sell for $270 new.
•Overall diameter: 93mm (3.7-inch)
•Mounting depth: 46mm
•Bolt Circle Diameter: 85mm
•Mounting hole: 74mm
•Pnom (without crossover) 25W (AES Standard)
•Pmax (without crossover): 50W
•Pmax (with recommended crossover): 150W
•Frequency range: 129Hz - 10,000 Hz
•Sensitivity: 85dB (2.83V/1m)
•Mms: 2.274g
•Cms: 640 um/N
•BL: 2.961 T*m
•Voice coil diameter: 25.5mm (1-inch)
•Impedance: 4 Ohm
•DC Resistance: 3.4 Ohm
•Fs: 129Hz (free air)
•Qms: 3.468
•Qes: 0.717
•Qts: 0.594
•Xmax: 2.6mm (one way)
•Vas: 0.63L
•Sd: 2733mm2
BNIB Zapco (ESB) 1.1" Reference Tweeter Set
$200
These tweeters are brand new in the box. The only time they have been taken out is for pictures. All Zapco speakers are made by a company out of Italy called ESB. The exact model number of these speakers are KT6.25. These retail for $307. I have the spec sheet for these and will gladly email it to you upon request.
4-ohm
RMS power handling of 100watts
90 dB sensitivity
BlkonBlkFG
BlkonBlkFG
IL
BlkonBlkFG
