Fs) DD m1c TONS OF POWER OUT OF TINYYY AMP
jfowler45
St.Louis
3) DD M1c
Brand new. These things are tiny yet deliver alottt of power for the size, i planned on installing them but due to bills i have to sell... These eat up a sundown 1500d, yet is almost half the size...
DD website description:
The M1 enters the "c" version, our most popular amp in its 4th generation. The M1 is the cornerstone for most subwoofer applications, delivering over 1200 Watts of true RMS power at 12 Volts. The M1c delivers over 1700 Watts of continuous power at alternator charging levels and capable of 2500 Watts of dynamic power. We have compacted the new layout and when combined with the LV type twin power supply, have reduced the width by over 2 inches and the height by half an inch. The smaller size allows a plethora of mounting options. 4 Gauge power connections and through bolted RCAs are provided.
Input Sensitivity 8V - 0.2V
Variable High Pass Filter
Variable Low Pass Filter 20Hz - 200Hz
Variable Sub-sonic Filter 10Hz - 50Hz
Variable Bass Boost
Tested Voltage 11.8
Tested THD ≥1%
Damping Factor
Signal to Noise >100dB
Channels
Cont Power at 1 ohm 1200W x 1 ch
Cont Power at 2 ohm 780W x 1ch
Cont Power at 4 ohm
Bridged
Dynamic Power 2500 x 1
Efficiency thru Output 80%
Dimensions - mm 350mm L x 175mm W x 51mm H
Dimensions - inches 13.8 L x 6.89 W x 2 H
Shipping Weight 11 lbs, 5 kg
MSRP $589
400 shipped obo
Price more negotiable for all 3.
included in price
It is sooo tiny as well.. i have 5 m3a's as well and this thing just looks like a tiny m3a... its craftsmanship at its best... half the size of a sundown yet gives just as much power...
Trades?? I know you have bills but gotta ask //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Who had that Badazzed Astro Van?? I remember going to Austin seeing that ride. That thing made Earth pavement move about 50 ft before I got close...
587
Run the biggest AGM you can under the hood, the parallel runs to one of these - should be everything you need and then some...
752
What amplifier(s) are you using? What speakers? Is this your main battery or is it a 2nd battery? If it is a 2nd, how are you wired up? What if...
571
jfowler45
jfowler45
St.Louis
eismanx
Decebal
    Jun 10, 2024
Decebal
    Jun 10, 2024
