I feel like i've gotten in over my head, and i need to pay off some debt, so here it goes.. all for sale/trade.
Image Dynamics Chameleon CX62 Midwoofers SOLD
These are for the mids only, one mid is missing the phase plug, however that does NOT affect performance in any way shape or form, and these are in absolutely perfect functioning condition. Taking offers on these.. throw PMs at me, i know these will probably sell fast.. UPDATE: Checked both coils, they both read ~2 ohms, so neither of the drivers are blown at all.
Max Fidelity MDFT30neo Tweeters SOLD
Just bought these from Meniscus Audio last weekend, by far the best tweeters i've ever owned, simply amazing... Might as well be new, but they have been used for about 30 minutes of play time, comes with all mounting hardware... Small dent on one of the tweeters grill, and they came from Meniscus like this. Doesn't affect functionality at all. $100 shipped
Mids and Tweets together for $175 shipped, an incredible deal
MTX Blue Thunder PRO150X2 Amplifier
Specifications
RMS Power measured at 12.5 Volts DC:
75 watts x 2 into a 4 ohm load with less than 0.05% THD+N
150 watts x 2 into a 2 ohm load with less than 0.1% THD+N
300 watts bridged into a 4 ohm load with less than 0.1% THD+N
Dynamic Power (IHF-202 standard) measured at 14.4 Volts DC:
120 watts x 2 into a 4 ohm load
212 watts x 2 into a 2 ohm load
425 watts bridged into a 4 ohm load
Signal to Noise Ratio
> or = 110dB A-Weighted
Damping Factor:
>200
Maximum Input
8 Vrms
Frequency Response
20Hz-20kHz ±0.25dB
Bass EQ
(0-18dB) centered at 45Hz
Crossover
Variable 40Hz to 175Hz
12-18dB/Octave
HP or LP configurable
Dimensions
9" x 9" x 2" (22.8cm x 22.8cm x 5cm)
10-1/4 Wide Including IsoFeet (26cm)
PICTURES
One of the amps has a few scuffs on the front, the other is basically mint.
______________________________________
i have two of those, hopefully would want $60 shipped for each, or $100 shipped for the pair if shipped to the same location. they're in the condition i got them in, which was straight from the refurb factory, some small blemishes on the case but otherwise working perfectly.
MTX Blue Thunder PRO50x4 Amplifier
Specifications
25 watts x 4 into a 4 ohm load with less than 0.1% THD+N
50 watts x 4 into a 2 ohm load with less than 0.3% THD+N
100 watts bridged x 2 into a 4 ohm load with less than 0.3% THD+N
65 watts x 4 into a 4 ohm load
125 watts x 4 into a 2 ohm load
250 watts bridged x 2 into a 4 ohm load
Damping Factor:
>200
Maximum Input
8 Vrms
Frequency Response
20Hz-20kHz ±0.25dB
Bass EQ
Crossover
12-18dB/Octave
Dimensions
11" x 9" x 2" (27.9cm x 22.8cm x 5cm)
12-1/4 Wide Including IsoFeet (31.1cm)
PICTURES
As you can see it's basically in perfect condition.
________________________________________
SOLD for this.
That's all for now.... talk to me
Specifications
Damping Factor:
>200
Maximum Input
8 Vrms
Frequency Response
20Hz-20kHz ±0.25dB
Bass EQ
Crossover
12-18dB/Octave
Dimensions
PICTURES
Specifications
Damping Factor:
>200
Maximum Input
8 Vrms
Frequency Response
20Hz-20kHz ±0.25dB
Bass EQ
Crossover
12-18dB/Octave
Dimensions
PICTURES
SOLD for this.
