FS Batteries CHEAP!!
michaellane
tx
Don't pay $80-100 for a used HC600 or Batcap 800, or even more for a XS D680...get more power reserve, and for less $$!
21lbs
26ah rating
7" long x 6.5" wide x 5.2" to top of tabs (rounded up a tiny bit)
Totally sealed and non-spillable AGM technology
40% more weight and higher ah rating than a Kinetik HC600 or XS D680
Resting voltage is between 12.+
All load test just like they're supposed to.
This will make a great secondary battery for mid size systems that need a little extra reserve power for when the alt just can't quite keep u
never used all sit at 12.4 or higher. ALL ARE BLACK
$53.00 shipped
Yep its funny you're a scammer and mad I wont deal with you. Don't start trash with me
Respect Mike.That's how it should be. //content.invisioncic.com/y282845/emoticons/respekt.gif.b162d148236010609fe523122efe3729.gif
You got to stand for something. Cant make this place better if im supporting tbat idiot
Can the cases handle engine heat
That I honestly do not know. Ive never ran these under the hood. In my opion if they aren't right ontop of it then I think they would be fine but I dont knkw enough to say for sure. Buy a few and try it out
374
How have you verified that your alternator is making that much current under real world operating conditions in your vehicle?
That would be close to 4000w rms give or take. I recommend a 75ah or larger AGM battery and a 240a or larger alternator. And you will need 2/0 or...
NADBL is the org that we get up here in the northeast, they do some shows in Ohio and upstate NY and into Canada, might be close-ish to you...
36
4K
michaellane
michaellane
tx
mrbadwrench
    Jun 1, 2024
    May 31, 2024
