FS Batteries CHEAP!!
michaellane
tx
Don't pay $80-100 for a used HC600 or Batcap 800, or even more for a XS D680...get more power reserve, and for less $$!
21lbs
26ah rating
7" long x 6.5" wide x 5.2" to top of tabs (rounded up a tiny bit)
Totally sealed and non-spillable AGM technology
40% more weight and higher ah rating than a Kinetik HC600 or XS D680
Resting voltage is between 12.+
All load test just like they're supposed to.
This will make a great secondary battery for mid size systems that need a little extra reserve power for when the alt just can't quite keep u
never used all sit at 12.4 or higher. ALL ARE BLACK
$53.00 shipped
What u asking for Deka9a31's?
I havent said I was selling any as of yet. I dont really care to deal with shipping since they are so big. Send me a PM on what they normally go for shipped
These go quick. this is all that sold since sat night to today
---------- Post added at 11:52 PM ---------- Previous post was at 11:52 PM ----------
been super busy ill get a quote tomorrow
Are these the only terminals on them???
Yes. You use ring terminals just like you woukd with batteries that use the bolt type terminals.
---------- Post added at 09:01 PM ---------- Previous post was at 09:00 PM ----------
noob question: how do you hook up to those terminals?
Ring terminals on the end of your wire and nut and bolt it on. Very simple.
145
How have you verified that your alternator is making that much current under real world operating conditions in your vehicle?
That would be close to 4000w rms give or take. I recommend a 75ah or larger AGM battery and a 240a or larger alternator. And you will need 2/0 or...
NADBL is the org that we get up here in the northeast, they do some shows in Ohio and upstate NY and into Canada, might be close-ish to you...
36
4K
michaellane
michaellane
tx
mrbadwrench
    May 16, 2024
    May 16, 2024
