Sold FS: 4 Treo SSX 12s
Treo15x2
1. Product:
Custom Treo SSX 12s
2. Specs:
2,500 daily
10,000 burps
3. Description/Condition:
These are not normal SSX's they have a stiffer cone, a stronger surround, same spider and a beefed up coil. I went from 2 normal SSX 12s and did a 152.8 and with the same amp and ohm load did a 153.6 with 2 of these
Dual 2ohm
4. Price:
350 a piece for the good 2
250 a piece for the glued 2
Also taking trades not really looking for anything so offer up if want
5. Pictures:
Two of these have a yellow spider and the spider was starting to tear so I glued them with some glue treo sent me and then also resin the cones and it helped alot and they have not came apart since they still play perfect and sound perfect. The other two have a black spider thats a little stronger and has an extra bead of glue treo put on before they sent them to me around the triple joint to keep them from tearing
nom nom, i just jizzed mah pants. wouldnt happen to have an older model SSX750.1 would you?
pm me if you do, i saw the team gorilla and thought id ask
No I dont have one of those although I do have a Treo CXT 4.1i for sale
Treo15x2
Treo15x2
Ohio
schrummy
