got a nice one with 1 little scratch,doesnt look like its ever been mounted.
asking 200 plus ship.has cartoys 5 year extended warranty.
WELCOME TO CARSOUND.COM
JL AUDIO E6450 Specs
Measured Performance
Measured Power (CEA-2006 Standard): 72.7 Watts x 6 into 4 ohms; 107.8 watts x 6 into 2 ohms; 215.5 watts x 3 into 4 ohms
Sub Channel only (Channels 5 & 6 at 50 Hz): 107.6 watts x 2 into 4 ohms; 181.6 watts x 2 into 2 ohms; 363.3 watts x 1 into 4 ohms
vSignal-to-Noise (CEA-2006 Standard): 100 dBA
IDLE/MAX Current Draw: 1.9 amps/76 amps
MAX Efficiency: 60% @ 2 ohms stereo all channels driven 1/3 Efficiency
25% at 2 ohms all channels driven
GENERAL SPECIFICATIONS:
Recommended Fuse Value: 60A
Recommended Fuse Type: AGU, AFS or MaxiFuse
INPUT SECTIONS:
No. of Inputs: Three Stereo Pairs
Input Type: Differential, noise-canceling with RCA jack inputs
Input Range: 200mV - 8V RMS
AMPLIFIER SECTION:
Amplifier Topology: Class AB with patented Absolute Symmetry dual N-Channel MOSFET output design
Power Supply: Unregulated MOSFET switching type
Rated Power (Stereo): 45 watts RMS x 6 @ 4 ohms. (12.5 volts); 75 watts RMS x 6 @ 2 ohms. (12.5 volts)
Rated Power (Bridged):
150W RMS x 3 @ 4 ohms. (12.5 volts)
THD at Rated Power: less than 0.08% @ 4 ohms per channel
(20 Hz - 20 kHz)
Signal-to-Noise Ratio: greater than 104 dB referred to rated power (A-weighted, 20 Hz-20 kHz noise bandwidth)
Frequency Response: 10 Hz-25 kHz (+0, -1 dB)
CROSSOVER FILTER:
State-variable, high-pass or low-pass 12dB/octave Butterworth with continuously variable cutoff frequency selection from 50-200 Hz (Defeatable).
DIMENSIONS (L x W x H):
17.7- x 9.25- x 2.36-inches (450 mm x 235 mm x 60 mm)
NO TRADES,TRYING TO GET A BIG ROCKFORD 5 CH. OR WILL TRADE TOWARDS ONE OF THOSE.
INPUT SECTIONS:
AMPLIFIER SECTION:
(20 Hz - 20 kHz)
CROSSOVER FILTER:
