Sold FS: 4 Sundown e8's & CMASS UL12
bones22
id like to just sell everything all together. id be willing to split though i guess.
ive had a couple pm's that bring me to this.
i WILL NOT ship outside the US and possibly to Canada
there have been way to many scammers and people getting screwed. EXAMPLE: kmanian losing a ton of money and the items being sold when the buyer clearly got the items
Critical Mass UL12 (the box has some damage BUT is not the box this one came it.
i used the original box to ship one of my others since i planned on keeping this one.
(NEW) Sundown e8's (opened boxes)
CMASS
RMS Power handling: 2500 Watts (undistorted power)
Peak Power handling: 5000 Watts
Recommended Box Volume: 1.2 cuft. (Sealed)
Weight: 16.6 lbs
Motor Type: Dual Gap / Internal NEO Magnet
Voice Coil Type: Ultra-High Temp Dual Coil (Made in the USA)
Voice Coil Diameter: 3”
Voice Coil Impedance: 1.5 ohm nominal per coil
Xmax (one-way linear excursion): 36 mm (3” peak-to-peak)
Maximum Excursion (one way): 46 mm (Almost 4” peak-to-peak)
Sensitivity: 96.7 db (2.83V / 1m) (coils in parallel)
Sundown e8's
Rated RMS Power = 200 watts (VERY UNDER RATED)
Mounting Depth = 4.25"
Outside Dia. w/gasket = 8 5/16"
Inside Dia. 7.000"
Sealed Box: 0.280 ft^3 w/ F3 of 50 Hz (Qtc = 0.707)
Ported Box: 0.60 ft^3 tuned to 30 Hz F3 of 25 Hz
$975 shipped on the 48
CMASS UL12
you can see there are some very small scuffs on the bottom of the motor from when i was going to put them in my truck. never got around to it though.
coils both read 1.6ohm
the damage to the box that i have for this one since i used the other box to ship one.
i will be adding plenty of extra packaging to insure the sub gets there in 1 piece. probably shape some foam under the sub for it to rest in.
Sundowns next to the CMASS
bones22
bones22
in my house
bones22
