FS: (2) Sprinter S12V370F batteries
basscort2009
Banned
7,052
dallas tx
2 12 volt sprinter batteries
had them for about a year now. these are my last 2 that im selling so get them while there here. the street beat 4 3 time workd champion runs these batteries (9) of them on 8 sundown 3500s. only drops to 12.8 on SB run of 30 seconds. very bad a$$ batteries. mine rest at 12.7
awesome condition
70 lbs
4400 short circuit amps
125 AH
175 shipped FIRM each or 325 shipped firm for both
VIA FEDEX
I bought a 2/10 amp Schumacher charger and I've had one on a 2a charge for 24+ hrs. Im gonna take a pic when I take it off the charger and I'm gonna take a pic 24 hrs later after its off the charger. If there's a significant difference I'm done with it
I bought a 2/10 amp Schumacher charger and I've had one on a 2a charge for 24+ hrs. Im gonna take a pic when I take it off the charger and I'm gonna take a pic 24 hrs later after its off the charger. If there's a significant difference I'm down with it
The 2amp may take a good min like 2-3 days but it will still get u the same results either way. I hve not load tested iit yet
U can put them on the 10 amp charge so both batts get 5amp each at a time as long as there jumped together correctly. And take it easy on cussing me out VIA Pms that doesn't solve anything. I would cuss u back but it would only feed into u. Not wat Im about. Now once again ill be on here very seldom tommorow so don't post then expect a response 10 minutes later. Have a merry Christmas u and everyone else.
221
How have you verified that your alternator is making that much current under real world operating conditions in your vehicle?
That would be close to 4000w rms give or take. I recommend a 75ah or larger AGM battery and a 240a or larger alternator. And you will need 2/0 or...
NADBL is the org that we get up here in the northeast, they do some shows in Ohio and upstate NY and into Canada, might be close-ish to you...
36
4K
basscort2009
Banned
basscort2009
dallas tx
disturbed471985
SPLBassJunkie
    May 21, 2024
    May 20, 2024
