front stage help
foreverlow01
How's it going everyone? I'm needing help picking out something for my front stage in my show truck (94 chevy ext cab). I mostly only listen to metal/hard rock. More worried about sq but i do want to be able to get really loud when i want and keep up with my subs.My budget is around $200-250 tops. Doors have been sealed and the cab has been covered in fatmat from top to bottom. Thanks in advance for any help! Below is a list of what I currently have.
JVC kd-a95bt
Skar vxi 6.5 components in the doors 1 set (has plenty of highs but no balls)
Skar sk125.4 for front stage
Skar sk1500 for the subs
2 Skar vvx 10's ported @ 38hz in a custom fiberglass enclosure
The components are rated at 60 rms per side. The amp is rated at 203rms x4 @2ohm and 133 x4 @ 4ohm. Not sure how much power they are getting but cant be much. At high volumes they pop and on my headunit i have them cut off at 100hz.I'm not opposed to using pro audio but I've never heard any of them and I'm not sure what kind of sound processing I would need for them since my headunit isn't active.
I'm really just trying to achieve more midbass and I don't which direction to go. Keep my 6.5's for midrange and add a set of 8's in the doors for midbass or get rid of my 6.5's and go with better components like the jbl ms62 or some re xxx 6.5. So many options and not sure which one to pick...
foreverlow01
foreverlow01
Tyler,TX
jmilla17
AJ (ACE)
    Jun 28, 2026
