Loud reliable 4" speakers?
SubieSPL_Maniac
I'm looking to upgrade my front speakers, I have plenty bass but my speakers can't keep up, what are some loud 4" speakers I can put on an amp that would nice and clear, And can i keep up under $75? They would be running paired with the 6.5 also in the front
why 4"speakers if you already have 6.5s" in the front, send the 6.5's more pwr or upgrade them. putting a set of 4 inch speakers in the front will bring down your sound quality unless you go active and make it a 3 way front stage.
YEOUCH..... look at upgrading the front 6.5 "splits for a nice 3 way split system , should be able to get some with a 6.5 midbass, 3 or 4inch mid range and the tweeter.
if you put a 2way coax 4inch speaker in there it'll more than likely sound worse than it did without them
here is what it looks like
20140306_090242_zpsb2e68ede.jpg'%20alt='20140306_090242_zpsb2e68ede.jpg'>
If you look on the top right you can see where I had a tweeter, I originally had a component set up, but the cheap tweeters were too loud and made it sound bad and broke so I pulled them out and put in the 4" speakers in the doors. in the original spot is the mid bass woofer that was part of the component set
Powerbass 2xl 4" great little speaker
SubieSPL_Maniac
SubieSPL_Maniac
Boston, MA
jc4def
