Front stage build
Your comp choices are decent; the amps, meh.
(Curious why you gots two 4-channels and one 2-channel , there...?)
I would think you'd want/need to feed your 6.5's more than either of those two 4-channels offer
I dont know much about amplifiers but if i bridged the four channel amps specs say they would get me to 200 rms which i what i need. would that work?
And yeah i would like to look at better amps but im outta cash
Yes, and no. Bridging will get you closer to 200WRMS output, but you're losing channels to do so (dropping from 4- to 2-channels).
How will you power your tweeters if you bridge? Or are you only looking at getting the 6.5" mids, not the component set?
i want the components and the tweeters. im not really sure how to wire a front stage though. lets say that i went with the cadence 2 channel to keep it simple. i wire the crossovers to 4 ohm and from the crossovers wire to the tweeters and the components seperately right?
I have experimented with using 4 channels in bridged vs. active vs. biamp.
Proper crossover design can let you get away with bridged. this is the loudest option.
Active lets you take fine control over each driver. The result can be a bett sound stage at the sacrifice of overall volume.
At least, with the proper amp, you can wire either way.
Sundown has nice 4 channel amps for this flexibility.
blnk64
blnk64
Wattsburg, PA
brynm
