front stage amplifier
poolman966554
PA
I was wondering if many people run a 2 channel amp for front stage.
i was looking at a few speakers in the $60/pair range, but theyre all 4 ohm. (open to suggestions aswell)
i happen to have a 2 channel amp thats 75w rms @2 ohm x 2
So, i was thinking of wiring LF and LR in parallel, and same for the right side.
ill have a balance, but no fader. which is fine to me.
what do you guys think?
Front stage does not include rear speakers.
A 2 channel amp is fine if you are using crossovers. If active then you need a 4 channel at minimum.
Do not wire your speakers together as this will cause ohm load issues unless you know what your dropping down too.
Sent from my draconis using Tapatalk
i have a crossover i was planning on using aswell.
What do you mean dont wire speakers together? i assume two 4 ohm speakers will result 2 ohm in parallel? am i missing something?
and for opinions for speakers in the $60 price range, whats the consensus on the Pioneer TS-G1645R?
Edit: i just realized those are cruthfield prices...
Opinions please.
i have a crossover i was planning on using aswell.What do you mean dont wire speakers together? i assume two 4 ohm speakers will result 2 ohm in parallel? am i missing something?
Yes, but as i do not know everyone hear i do not know who understands ohm loads.
But yeah you got what i meant.
Get 2 ohm speakers... done... JBL GTO638 6.5" / 6.75" Grand Touring GTO Coaxial Car Speakers
A lot of JBL line of speakers is 2 ohm. If you want something nicer, look at the pb 660c
Very true. i didnt see that line of the many..
that said, i d need a new 4 channel amp the run all door speakers at 2 ohm.. is the rear door speakers not desired?
otherwise would my original plan to run 4(all 4 doors) - 4ohm speakers in parallel (L&R) still sound ok?
That said, i just thought about the front dash tweeters. theyre prolly connected in parallel with the front door speakers? ill prolly wanna replace them too. looks like i have homework to do
i ve added subs for years, never really overhauled a complete system..
Very true. i didnt see that line of the many..that said, i d need a new 4 channel amp the run all door speakers at 2 ohm.. is the rear door speakers not desired?
Rears arent too important, you can keep it on head unit power. Unless your car is like mines where its a complete road trip car and passengers need the rear fill loud to overcome the sub.
poolman966554
poolman966554
PA
Jeffdachef
ThxOne
    May 13, 2026
ThxOne
    May 13, 2026
