Front / Rear Comps Help
nbudros
E-THUG
1,328
DFW, TX
Im using a sundown 100.4, in a jetta, and i wana run a set of comps up front and a set in back, i want both sets from the same company. I also want the front ones to be nicer then the rear ones but i dont want the rear ones to be complete ****.
So with that said, i want a good set under 350, and a ok set under 200-250.
LEMME hear some ideas,
amp stats, 100x4@4 simple....
I have a MKIV Golf (Jetta - trunk) and have only Alpine Type X's up front biamped from an Infinity 7541a (4x111w rms).
Run comps up front, do away with the rears, and spend that $200-250 to get a sub (and amp if needed) would be my advice.
Thanks.
Ive just been debating on spending the lil bit on rear comps.. the panels got to come off for deadening any ways so i figured i would just put some in...
I have a SD SAZ-100.4 and a SD SAX-1500D.
Im pretty set on getting a DD3515... but havnt ordered it.. so im just researching and taking my time.
Thanks.
You can use that SAX-100.4 to biamp some Rainbow Germaniums CS265's. //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
You definitely won't need or miss rear speakers if you do your front stage correctly.
The end result is, not the intention. I think OP got what I was saying. The Brits generally aren't as sensitive. A 500w sub amp does not...
17
Hi again, I appreciate all the suggestions and have my budget minded options down to 1 or 2 choices. I have noticed CDT, Image Dynamics and a...
nbudros
E-THUG
nbudros
DFW, TX
///M5
