Front passenger speaker "pops" when starting car
Hi all,
I had component CDT CL-6 in the front (passive) and coax cdt cl-6ex rear running off Memphis mc2004 amp. Everything has been great, no ground loop or buzz or whine. No amp thump or crackling or anything until... I started to install new speakers (CDT HD-6cf). I've only replaced the front woofers so far, but I now get a loud pop from the right side when I start the car. This has never happened before. Wire is 16 gauge and I crimped on quick connects to clip to the speaker terminals (spades).
Could it just be a loose ground spade or perhaps not a good enough crimp on the quick connect? CDT's negative terminal is really skinny compared to the positive and the quick connect is a little hard to get on there tightly. The door is back on and I only have time to post, I'll take everything apart tomorrow I guess.
I've search a number of forums and google and surprisingly, I didn't find much in the way of results - I expected this to be somewhat common.
I'm grounded to the car, wire brushed the metal, 8 gauge wire to the amp. I have zero alternator whine or buzz. After the pop, music sounds fantastic. I don't have the polarity wrong.
Any ideas? I'm guessing the speaker is getting a power spike when I start the car - so I can only think it's a bad ground.
Speakers where bought new and look perfectly fine and sound great otherwise.
I'm stumped Thanks!
Tyler
Hi all,
I'm stumped Thanks!
Tyler
Heard this a few times with CDT comps. Swap them with the ones you had in there and see if it's still doing it.
is your turn on hooked to accessory or ignition?
sounds like something is backfeeding into the remote wire. try putting a diode on it. although it is weird only one speaker does it, but backfeed could also just be affecting only one channel on the amp for some reason.
Ya, I was thinking remote wire too. Def a wire problem between amp and speaker, not headunit. Does it without rcas plugged in. Thanks.
Tbonem3
Tbonem3
LA, CA
Tbonem3
