front comps and 2 idq 10's
  • Thread starter gijoe
  • Replies 0
  • Views 508
gijoe
I'm about to buy 2 IDQ 10's, they are the dual 4 ohm models and I need an amp. The amp I currently have is 350 watts at 2 ohms, 200 at 4 ohms. I want an amp that will also power my front components. I am currently running my fronts off of hu power, so even a little power up front will be good enough. I understand (correct me if I'm wrong) that with these two subs I'll either need an amp that puts out pretty good power at either 4 or 1 ohms. I've read that wiring these two subs at 2 ohms isn't possible. So I want an amp that is either 1 ohm stable to give these subs some juice, or has enough power at 4 ohms to get the job done. I'd like to only have one amp to run the comps and subs, so I'm thinking a good four channel would be my best bet. Do you have any suggestions on an amp, or do you think I should just run two seperate amps for my subs and comps? Any advise would be great, Thanks.
gijoe
gijoe
Littleton, CO
gijoe
michigan born
    May 14, 2026
michigan born
    May 14, 2026
