From RE Audio SE 15 to Re Audio XXX18
So how long have you been Building drivers?
The dd woofers don't really need a big box.. it depends on port are tuning and power.
I've had better results with the smaller boxes and a **** load of Port area . The larger boxes do good on limited power in some classes.
I tried from 3 cubes to 12 cubes for the 9515. Every cabin/car is different.
When I design a driver I use large signal parameters. Aka real world application.
You understand the dumax/knipple test?
Small signal parameters are cold..
Power compression is defined when the bl drops off very similar to the calculated b/l curves over excursion.
Powe're compression is normally considered non linear once qes is doubles..
Dd designs there woofers in the same fashion. The small signal parameters don't quite add up but that's typical when designing woofers in this fashion..
So how long have you been Building drivers?The dd woofers don't really need a big box.. it depends on port are tuning and power.
If you have done small box big port no wonder you think like you do.
That's the exact opposite
I just told ya I've tried from 3 to 12 cubes. In some cases bigger boxes did better esp with lower power. In subs and non walled bigger boxes did good. In the walls with 8k the smaller higher tuned larger port area boxes tuned to do better with that power..
If you say so. Sounds like you don't know what you are doing or just talking out of your ***.
Which one is better for hip hop music?
Which one requires a smaller box for the same cone size?
How many watts can they handle?
Which one is able to be fast even if the box is built to low frequencies? (for example after playing "young jeezy - Put On" you play some house/dance music and the sub is still ok and it doesn't seem to be slow)
steve89
steve89
london
steve89
