free simple box designs.
I need some help on getting some demensions on a ported box. Im putting 2 Xplod 15" woofers into a ported box. It does not matter how the port is weather its round or rectangle which ever is easiest. Feel free to call me if you can help me out. (304) 531 - 6112 Heres the info on the subs...
D(inches) - 12 1/2
FS (HZ) - 25
Qts - 0.62
Qes - 0.69
Qms - 6.35
Vas (Lit) - 110
Vas (Cu.ft) - 3.88
Lvc (mH) - 2.24
Xmax (mm) - 5.5
Xmax (inch) 7/32
BL ™ 14.8
Enclosure vol (Net) - 47.6 Lit (1.68 Cu FT)
Thank you!!!!!!!!!!! Im no expert at this I need some help!
16.5deep 30wide, 17.5high max dims
2.3cuft tuned @32hz
sub up, port back, double baffle, flush mount
left/right 16.5x14
back 14x28.5
front 26x13.25
bottom 30x16.5
top1 30x16.5 sub cutout 12 left and 8 from back 12.5 diameter
top2 28.5x16.5 sub cutout 11.25 from left and 8 from back 11.5 diameter
45's 4x13.25 (4) 13.25x 3 7/16 (1)
port 1; 10 13/16x13.25 45 on one end.
2; 15.75x13.25 45 on one end
Uploaded with ImageShack.us
D(inches) - 12 1/2
FS (HZ) - 25
Qts - 0.62
Qes - 0.69
Qms - 6.35
Vas (Lit) - 110
Vas (Cu.ft) - 3.88
Lvc (mH) - 2.24
Xmax (mm) - 5.5
Xmax (inch) 7/32
BL ™ 14.8
4 cubes @ 33Hz
36w 16 tall 19.25 deep.
front 36x16 sub cutouts 7.75 from left and 8 from port opening centered at 8 high port .75 from top bottom and right sides. 3.75x14.5 cutout.
back 14.5x34.5
left/right 14.5x18.5
top/bottom 18.5x36
port parts wall 1 12x14.5 45* cut on one end
wall 2 7x14.5 45* cut on one end
45 for wall. 3 7/8x14.5
45 for corner 5.5x14.5
dowel/brace 17.75x1.25 diameter (2) placed btwn subs at 5 and 11" height (internal)
had to call sony to find out the ID and OD on these lol.
marcotheclepto
marcotheclepto
United States
ktraughb
AJ (ACE)
    Jun 24, 2026
AJ (ACE)
    Jun 24, 2026
