Form Tube Port help
  • 5
Those MDF ports gotta be heavy as fawk.. lol As for mounting the form tube, I used 2 pieces of MDF squares ust over the size of the tube. Then cut circles in each piece just big enough for the tube to fit inside. screwed/glued the MDF squares together and layed them flat on the ground and dropped the tube in and loaded it with gorilla glue and put a brick on top of the tube to hold it still while it dried. Now you can just screw the MDF squares to the inside of the box and use a flush-trim bit on a router and get the perfect circle by going around it after you've mounted it. Then a nice round-over bit to flare it.
CAF, Williston Audio Labs(Old School Car Audio) and Jonathan Patrick's Brand X videos when I'm trying to wire an alt into a newer vehicle I...
16
Yeah, saw that too, was like ??? wtf! They do know there stuff, I usually just roll with it!
13
You could try to make the port longer, but there might be other reasons with the box won't extend lower, or even the sub. You'd have to reverse...
800
While that program is pretty neat, it assumes you know the values. I was just recapping the numbers you provided. RS recommends the following...
981
BoomBoxStereo
@woofergram
BoomBoxStereo
Long Island, NY
dB-SPL
